macaroni 17 1 Cars Posted April 17, 2007 Would a K-reg 1.1 205 have a cat converter fitted? Share this post Link to post Share on other sites
GazRallye 0 Posted April 17, 2007 Possibly, my mate has a 1.1 on a J that is carb, i've seen K plates down the breakers that are on injection and therefore have a cat My old AX was an early K from 1992, that was a 1.1i with a cat, think the new emissions law or whatever it was came out for the first of the K plates as far as i know Share this post Link to post Share on other sites
stealth_pug 0 Posted April 17, 2007 My K plate 205 1.1 was a carb with no cat. I think it was somewhere between the K plate as L plates had Cats. Share this post Link to post Share on other sites
number2301 1 1 Cars Posted April 17, 2007 I seem to remember seeing a CAT 106 XSi 1.4 on a 91 plate. I imagine its like the 205 where it was optional for a while? Share this post Link to post Share on other sites
Sandy 191 Posted April 17, 2007 More than likely. I used to read Autocar in the library at college every week around 91-92 (beat telecoms lectures!), most Peugeots had a cat option about then. Share this post Link to post Share on other sites
Rippthrough 98 Posted April 17, 2007 '93 standard fit IIRC. Share this post Link to post Share on other sites
DaveW 6 Posted April 17, 2007 My rallye is a 93 no cat as its on a carb. Share this post Link to post Share on other sites
welshpug 1,736 Posted April 17, 2007 thats because it was produced before august 1st 1993 Share this post Link to post Share on other sites
Guest martyn_mcg Posted May 4, 2007 you can take your cat off any car with a carb even if it was made after august 1993, i had a late 93 mini which i took the cat off and that past 2 mots fine, i even asked the mot inspector and he said its not a problem!!! (ring your local mot station and check but i do belive this to be a perfectly legal loophole) Share this post Link to post Share on other sites
Casanova 0 Posted May 4, 2007 You can take the cat off your brand new car as long as it passes the appropriate emissions test at MOT time. Its just that most cars which have a cat have it because they need it to pass. § Share this post Link to post Share on other sites
swordfish210 20 Posted May 4, 2007 "Cars produced after 31st July 1992 must be fitted with a catalitic converter" according to my MOT tester Share this post Link to post Share on other sites
Guest martyn_mcg Posted May 4, 2007 hmm.. i i do belive that if your car passes the emissions test it dosent matter if there is a cat or not, i was told from several people prior to taking the cat of my old car that it would be fine, and as i said i went through 2 mot's without it. Share this post Link to post Share on other sites
