KRISKARRERA
Changed My Hinge Pins!
KRISKARRERA
I just renewed my "hinge shafts" on my drivers door.
I'd ordered just the one from the main stealer but somehow he ordered a whole packet of them which was handy as I finally managed to undo the lower bolt that had been stuck solid for weeks.
Look at the state of this:
Very worn and slightly bent!
I'm getting better at fiddling with cars these days. Did my front suspension, and rear, and now my hinges. :)
Just slightly worn then...
And no posts about getting stuck, I'm impressed
Edp
:D
KRISKARRERA
did it remove the play
Believe it or not I've not fully tested for that, I'd rather not try to lift the door in case I bend the new pins. Not likely I know but all the same. However, the door no longer catches on the latch so yes it must have taken away most of the play.
Anton green
Glad it is sorted.
I believe the are two different types of hinge pin on the 205 -Mine arent like yours unfortunately so I will be going into uncharted territory when I replace mine. -I have been told that the pins aren't what wear on my style of door!?? So I'm expecting a fun afternoon seeing what is going on there
