M_R_205 5 1 Cars Posted March 24, 2007 well well well what a day im having, i have a wiring loom that came off my mi16 and it has a dizzy plug in it, i dunno if this is normal or the tool i bought the engine off had a gti loom on it, im not that good with wiring so i need lots of help pls any way, to my problems fitting carbs to an mi16, i am following the wiring diagram on the main site but i seem to have a different coil to the diagram which is where my problems are, as there is 7 wires coming off it, and i dunno where they all go, two of them go to the ignition amplifier (as pointed at in one of the pics) the thin white one im guessing goes to the rev counter, but the seccond red and twoo black i have no idea what to do with, (the two black one goes to the ecu and the other the tach relay, and the red into a brown connector ) and finaly, its going into an xs, where can i take a switched live from the std xs loom??? pics at this link http://s91.photobucket.com/albums/k296/con...d_waugh/wiring/ all help needed even if u think its a daft comment cheers in advance Share this post Link to post Share on other sites
Richie-Van-GTi 74 2 Cars Posted March 24, 2007 the coil may be different but wiring is the same, the hard part is knowing which wire does what as its not as obvious as the single cylindrical coil's. You could always chop the wires and use a different coil. Im not 100% on the wires on the coil you have? Share this post Link to post Share on other sites
M_R_205 5 1 Cars Posted March 24, 2007 it looks like the fat red wire goes to a switched live, (the one in number 4 on the right) dunno about the litle white one attached to it :S as for the two black ones i have no idea im thinking of just cutting them off any ideas?? Share this post Link to post Share on other sites
pug_ham 245 3 Cars Posted March 27, 2007 http://www.205gtidrivers.com/articles/e1-carbs1.html Any help? Graham. Share this post Link to post Share on other sites
