pee vee
1905 Cc Mi16 Distributors
pee vee
hi all.
are the dizzys on alloy block Mi16s literally JUST a dizzy,
or does the ECU have some say over the timing of the ignition???
also, what advantages/dis-advantages are there to running a 8v dizzy
on an mi16 engine (with conversion plate)
thanks!!
Ahl
The timing is controlled by the ECU on all of the mi16s, just the alloy mi16 has that dizzy cap to distribute the spark.
Its an easy way to run carbs. Apart from that, it is a disadvantage over the proper mi16 management.
pee vee
thanks a lot AHL!
Its all becoming more clear to me now!
