Headling
Removing Sunroof!
Headling
HI Guys, I have a 1.9 gti 1990, going track daying and want to take out the sunroof and panel in, I have done a search on it and found the carbon roofed white 205, looks trick and the red rally 1.6 put with steel panel in where glass used to be.
My car has a sliding sunroof. I cant afford a roof re skin so cheap and cheerfull is the way! ;)
What is best to panel in with, I may want to race one day so want to do it right and pass scrutinering?
Ali,steel,carbon?
How to remove it? I have taken head lining out and can see what look like rivets? do you drill these out from inside? Any tips would be great.
cheers,
Mark
ashley peddle
i done a group buy on roof plates... i can help talk you through it if you wonna add me to msn ;)
peddle_ashley@hotmail.com
Headling
cheers Ashley I will drop you a mail and have a chat on it, looks good in the picture, just got my steel plate this arvo, £7.50! the grinder and paint are coming out to play this weekend! oh and a bit of silicone sealant.
Rippthrough
Why not ally? :D
Headling
I was thinking that steel would be stronger and if I want to go racing one day steel would pass through scruitnering a little easier than ali? just my thoughts though, I can do it in ali if thats ok?
chris1986
did you het this sorted? i'm soon going to be doing this to mine. it has the massive sliding glass roof
