Casanova
No Second Gear On Rebuilt Xs
Casanova
Hi there
Apologies for my first post on this site being a technical question. I have had a couple of searches but I can't find a situation quite like mine.
I have a 1989 205 XS that I bought as a non-runner and fitted a rebuilt engine to (using the original gearbox). The car has done 110k. After the rebuild the linkage was hugely sloppy and only 1st, 3rd, 5th and reverse could be selected. That was solved by replacing the pivot bolt on the linkage bracket that bolts into the subframe and now it's sufficiently tight to drive normally (tight for a 205 that is!).
However, when you select 2nd gear and release the clutch, the engine just revs freely. There are no unfamiliar noises. With the clutch depressed, you can slot the gearstick more firmly into second and it grinds. I suspect something within the gearbox is amiss, but am not certain enough to go and change the box just yet.
Any thoughts or guidance? If I do replace the box, is there a page of final drive ratios for different MA boxes I could consult?
macaroni
Hello and welcome.
If you are happy that you have selected 2nd I guess it is internal.
Can you move the selector lever on the gearbox successfully and try then?
Replacing the box is an easy job and there should be a page of ratios somewhere, either here or on the net.
The xs box has lowest ratios of any TU car, so stick with that for best acceleration.
Antony
stu_woac
sound like the plastic clips on the end of the selector rods have completely gone on secound gear you could just get a rebuild on the box, or try and try and find a good xs box as they are very very rare now, so look for a 1.3 106 rallye box or a vtr box maybe, I ran a saxo box for a while with no problems
The later MA boxes use the later type selector (as the BE's) and which Stu's got in his, If the clips break it normally makes the shift somewhat vague
Jrod
Is the 106 1.3 rallye box much longer ratios?
trogboy
No. AFAIK it is actually the shortest of all of the MA boxes not all that much shorter than the XS box though.
Casanova
So it looks like I need a new box then :)
I have been looking around for a page of MA transmissions, & which were fitted to which PSA cars. The best I have found is this: http://pages.zoom.co.uk/rossd/engines.htm
I know the box in mine is also in other TU3S cars, but I'm not doing very well so far looking for a replacement. Is a VTR box quite close to mine? How much should I pay?
Miles, is having a later-type selector better or worse - how do they differ? What year was the changeover?
Thanks :D
Edited by Casanova
Casanova
OK, I found another possibly useful page on gear ratios:
http://www.saxperience.com/forum/showthread.php?t=5148
yeah any post 92 box will fit any tu engine the gears are all different but keep ur vtr box as it is much shorter cut resulting is some wicked accel times,only draw back is that u will use abit of fuel crusing at 110mph but drop it to 80-90mph and it should be cool,thats only on long journeys. hear are a list of the gear ratios i found
954 cc and 1124 cc
1st===3.417:1
2nd===1.180:1
3rd===1.276:1
4th===1.026:1
5th===0.767:1
rev===2.500:1
final drive===4.286:1
1360 cc
1st===3.636:1
2nd===1.950:1
3rd===1.276:1
4th===1.026:1
5th===0.767:1
rev===2.500:1
final drive===3.765:1
1587 cc (vtr)
1st===3.417:1
2nd===1.810:1
3rd===1.276:1
4th===1.026:1
5th===0.767:1
rev===2.500:1
1587 cc (vts)
1st===3.417:1
2nd===1.950:1
3rd===1.360:1
4th===1.050:1
5th===0.850:1
rev===2.500:1
final drive===3.938:1
Aside from my suspicions over the reliability of that information, I think the ratio for 2nd in the 954/1124 box might be a typo. Looks like it should be 1.810. Am a bit puzzled as to what all these figures mean too... ;)
Edited by Casanova
Casanova
And another page, feel like I'm getting somewhere now. I found this:
http://www.suzukituning.com/PSA/MA5%20Gear...a5gearratio.htm
This page gives the following table of ratios:
Now to work out what mine is, and source/build a close-ish replacement. I perhaps wouldn't mind a longer 5th for motorways...
Casanova
I got the urge, so I went out to see what the code on my box is. Its a 2CA18, which handily isn't in the above table. Until I get it to bits then, I'll assume its the same ratios as a 2CA08 which is what the first link says a TU3S used. ;) Think I fancy re-building a box, so I shall gather bits and do it when I get some time (summer probably...)
