acox99
Rough Running 2ltr Mi
acox99
finally got it running tonight, after sussing the problem of 2 plugs being the wrong way round, the engine is very tappy, and is not running on one cylinder, cam belt was too tight so loosened it off by undoing the top tentioner slightly, the engine bogs out when revved, is this due to firing on 3 cylinders, or could the timing be slightly out, is there a way to adjust the timing on these, as you dont have a Dizzy?
