Kriss
The 1,4i Tu
Kriss
As the title suggests, got a 205 1.4i for £220, goes well, but a bit lacking in the power department. I was just wondering what stuff is out there to give it a bit more go. It's getting a 1.1 straight through pipe, stainless back box and green filters replacement element air filter. Just wonderinbg what else could be done. My mate has suggested carbs.
bren_1.3
generic reply................
List of parts to buy.....
exhaust manifold
cam
port work
carbs
throttle bodies
block decking
cylinder head skim
List of things to do....stop driving in a straight line. 100 bhp down the twisties is more than enough.
N.B generic reply to search the TU section on tuning options....
calvinhorse
turbo
Jrod
Supercharger...
swordfish210
if its a single point injection model then junk that and go for a multi point set up, its cheap and easy to fit and an instant gain
Enfield
Is it a 1.4 GT with single point bosch injection yeah?
The best mod I did for that car was fit a universal cone air filter to it upside in the original filter housing.
The difference was very noticeable, not to mention the noise...
Kriss
well, i work in a parts shop, that would be a cheap option for me. Yes it's single point bosch injection. Got a new problem now however, it decided to jump out of 3rd and 4th gear last night. Only happened on rough roads, think it might have something to do with the fact the clutch pedal seems really stick. Could anyone clarify this for me
Jrod
Low gearbox oil?
Knackered engine mounts?
Kriss
i've got it sussed. It's the gear linkage. Need to adjust the clutch cable aswell
Guest inflames
is the 1.4i 100bhp? ive got the same but a '94 205 sceptre, starting to realise after changing backbox for straight through, that its loosing power the more i do to it! any ideas?
swordfish210
the 1.4i with single point injection was rated at 75bhp but with multi point injection (as used in AX GTI's) it was 100bhp
johnnyboy666
you definately need to get some go faster stripes on it if you want any real power ;)
bren_1.3
yeh stop messing with it ;):wub::wub:
