Guest dwwilson
Tick Over At 3rpm
Guest dwwilson
hi just joined up have been through tons of posts.ive just fitted another engine in my 1.9 and it will not tick over.it goes up to 3000 revs when you rev car it dies out,ive tried air flow meter, tried doing tick over and air flow screw its still the same.i have put new gasket on injection manifold,car drives good over 3000 revs under 3000 and its sluggy any suggestions as ive been trying for weeks now,cheers dave
You've not left the bolt that secures the oil filler to the side of the inlet manifold off have you? I know from experience that'll cause a high cold idle.
Spiky
the SAD try bypassing it first, i,e, block the ends, see what happens
though doing this it wont tick over when cold :unsure:
j_turnell
Sounds like quite a large leak, i'd whip the inlet off again and make sure its sealing properly.
Guest dwwilson
hi anthony thanks for speedy reply just tried that it has solved my problem top man thank you :unsure:
