Craigb
Injector Firing
Craigb
I did my first road rally of the season on saturday night , well at least i started my first one .
Prior to the rally , because of all the niggley problems last year , it has had a really good test over 200 miles in the last two weeks . all of which has been faultless.
Come saturdays and the start of the Bruce Robinson , everything fine on the run up , the first section was cleaned and the engine was sweet .
About 2mins into the 2nd competitive section , i slowed for a code board and it died , then it fired , and 100 metres down the road it died .
An under bonnet inspection revealed that the injectors were firing even though the engine wasn't running .
Then they stopped , so i put the bonnet down , and did another 150 meters then same again .
I believe it will be a wire or some thing dropping them to earth , but how bloody frustrating .
It nearly had a flame thrown at it.. :)
Lets see if Karl at Emerald can point me in the right direction .
A couple of good points though , the new spherical top mounts improve the front end , and the exhaust was quiet enough to go through noise without having to resort to the Brillo pad :D
Craigb
Dr Karl's prognosis is possible water in the ecu ;)
So its off for a check up today and an upgrade to K3 :)
smckeown
Dr Karl's prognosis is possible water in the ecu :o
I was glad to learn the DTA S60 was waterproof. My car leaks like a good one!
So is the k3 waterproof too ? highly useful on your type of car i'd imagine
Craigb
Guess what my first question was when i was told it could be water :)
Craigb
Just had a message from Karl
Ecu upgraded , imrpoved sealing , should be back with me by friday .
Top quality service .. :blink:
