sam1312 0 Posted January 29, 2007 (edited) DTA f48 i have one of these ecu's and ive got the softwear from their web site i just need to make the comms cable now, has anyone made this cable before? if so could you tell me the wiring numbers any help will be gratefuly accepted Edited January 29, 2007 by sam1312 Share this post Link to post Share on other sites
M@tt 77 Posted January 29, 2007 you just make a straight through cable, wiring pins 1 through to 5 ie pin1 to pin1, pin2 to pin 2 etc you need the 2 differnet connectors which can be got from maplins and a ethernet cable is good for the job if you have got a spare one This might be a useful bookmark for you http://dtaforum.psycode.com/ HTH Matt Share this post Link to post Share on other sites
smckeown 1 Posted January 29, 2007 I'm making an s60 flash cable at the moment. I got all the bits from maplins. The wiring diagram is in the manual or on the DTA forum as listed. Share this post Link to post Share on other sites
sam1312 0 Posted January 29, 2007 so its a 15pin conector at the ecu side and a 9 pin conector at the laptop side, and its just like for like 1-5 ie 1-1 2-2 3-3 4-4 5-5 also my laptop doesnt have a serial port so i was going to use a serial to usb adaptor will this work? Share this post Link to post Share on other sites
M@tt 77 Posted January 29, 2007 (edited) thats correct with the wiring usb-serial connectors are a bit hit and miss i bought one off ebay to help with 309Pugs dta but it would not work with my laptop at all. In the end i just got a s*itty old laptop running win95 that had a serial port and used that, worked like a charm. You can pick em up off flea bay for next to nowt Infact this is pretty much the one i have http://cgi.ebay.co.uk/Old-Toshiba-Satellit...1QQcmdZViewItem £32 can't be bad!! Edited January 29, 2007 by M@tt Share this post Link to post Share on other sites
Sandy 189 Posted January 29, 2007 This link tells you exactly and includes trim wheels if you fancy it. http://www.quantums.info/dtalead.htm Share this post Link to post Share on other sites
sam1312 0 Posted January 29, 2007 thank you for your help guys i will let you know how i get on cheers Share this post Link to post Share on other sites
