SimonJ
Driveshaft Removal
SimonJ
About to change the engine and remember the last time I did this (many years ago) the offside shaft split at the bearing carrier and I didn't get it put back together again - ended up exchanging it for a new one. Any tips on how to avoid the same mistake this time round?
phonecomz
Have a look at this thread Simon
http://forum.205gtidrivers.com/index.php?s...c=69780&hl=
Follow the advise and you shouldn't go wrong.
:rolleyes:
C_W
Basically make sure the 2 11mm nuts are undone, pushed through and turned 180degrees, then hit the shaft outwards from the behind the engine mount.
Alastairh
But don't what ever you do pull the shaft from between the hub and the mount as you'll mess the bearings/gaitor up :rolleyes:
SimonJ
Thanks everyone.
