coombsfh 2 Posted January 21, 2007 Been searching and would like something clarifying please. Do both boxes willingly accept the gear rods? When on is it only the shortest of the three that needs adjusting to set the central position of the gear stick? Would it be a massive or worthwhile or cost effective (gearbox on or off) job to change the gearbox mounts? Swift replies would be lovely. Merry sunday, Fred Share this post Link to post Share on other sites
welshpug 1,629 Posted January 21, 2007 gearbox mount is easy to change remove battery place jack under gearbox and take the weight unbolt and remove the mounting fit new mounting and its central nut remove jack so that the mounting takes the weight then refit the 2 nuts that hold the mounting to the battery tray. Share this post Link to post Share on other sites
welshpug 1,629 Posted January 21, 2007 as for the gear rods it depends which ones you get, some just push on others push on and you fit a clip, then you have rose jointed which takes a bit more to fit and is more expensive. not sure on the compatability of the rods, but whoever you buy them from should be able to advise. Share this post Link to post Share on other sites
Miles 331 1 Cars Posted January 21, 2007 The rod's all fit, You'll have to adjust the 2 shorter one's to suit, but it's always worth doing this as no 205's are really the same. Share this post Link to post Share on other sites
