rogerrally
Red Fliud Level Light On Dash
rogerrally
My central fluid light has come up on the dash waning center panel, but I seem to be ok for brake and water fluid levels, any ideas?
easypug
If its the one with 3 wavey lines then it is indeed the coolant level. Assuming you have the right amount in the headertank then it will just be the sensor that has gone.
The brake fluid low level light is the same handbrake light :(
Edited by easypug
tom_m
my fluid level light just means i am accelerating. and unplugging the sensor makes no difference! :( on mine i'm pretty sure its interferance from the HT leads.
nick
The clear header tanks don't seem to do it, only the black ones.
I've heard that it's interference as well.
Nick
pug-girl
Mine flashes under hard accelleration, but all fluids are fine so I've always just presumed it was the quality french wiring to blame!
tom_m
Nick
yup phase two black tank and sensor. phase ones have a different sensor as well as a different tank.
