Spiky
Putting Battery In Boot
Spiky
can i assume i just need to run 1 long (positive) cable to the boot, and mount a battery in a battery box and put the negative to the chassis???
is there a kit available??
Edited by Spiky
smckeown
my battery's negative terminal is mounted to the body behind passenger's seat
Guest purpletoddy
I am going to do the same on my 205.....I have done it before on a rover coupe I had and just used a longer positive cable to the boot which was fine.......many people said that due to the extra length more current would be drawn hence I would need a thicker cable but it never went on fire while I had it... you can get a junction box that you can bolt to the inner wing etc and run all +ve terminals to that so you dont need to splice them all together
Rik
What size wire are people using to run the positive then?
I've got access to some shielded cable so i might as well grab it while i can!
pdd144c
25mm. Don't really see why you would need shielded cable though.
Jrod
What happens with the earth off of the gearbox then? Do you connect that to the earth in the wing?
GLPoomobile
Somebody on here mentioned recently that if you are using a standard battery you need to have a vent to the outside due to battery fumes. Not a problem with a race battery though.
Rik
Cause its free! and all i can get!
work in A/C Production...
Rik
gizzmo
i will be going down this route in the not to distant future/ welding cable will be my choice. can be obtained in very short lenghts current carring capacity is very high thin multi stranded cable which is very flexible compared to say 25mm as used in house bashing it can also be terminated with a crimped lug or ferul or if u have a blowl lamp and stick solder and the know how it can also be soldered its such a short run volt drop will not come into the equation
Normski
^^^ Now that is a battery in boot. :)
blackpug
Yes, you need a good earth strap from the gearbox/engine to the body. With mine i made up a strap from the original gearbox earth point to the coil/ignition module mounting plate.
Ad.
sutol
Minis used a long cable to reach the battery in the boot and it was no thicker than standard cable of the time so no problems with overheating.
The cable was about 9 feet long :)
Rob_the_Sparky
Not a problem with overheating long wires but you can drop volts along them when cranking...
sutol
Voltage drop will depend on ambient temperature (hottest part near starter) and type of cable (alluminium / copper) and of course length of run.
Battery probably giving 14.4 volts and assume drop of 2 volts then cranking should be no problem.
Depending on cable length and current drawn by starter of course.
If using armoured (SWA) then don't run an earth back along the body too close to it or it will overheat. You wouldn't anyway bu don't.
Earth only needs to be to body near battery anyway. :)
Discostu
Heres my battery fitted in a box i made in the boot. As the battery is sealed it doesnt need venting to atmos. Also fitted a cut off switch, saves messing about when i'm working on the car:
Spiky
here's my stuff ready to mount it in the rear, well behind passenger seat
MikeHunt79
This is true, as normal batteries release hydrogen when being charged. If it is not vented, and someone lights a fag up in the front, then you've got a French Hindenberg! :)
pdd144c
It's not really that bad is it? It's not like there's no chance of sparks occuring under the bonnet normally?!
Gentrix
Under the bonnet is more than enough venting to air.
it´s Hindenburg btw. :D
andi
gizzmo
Earth only needs to be to body near battery anyway. B)
hes trying to put a battery in a boot not a fishpond :D
just call your local welding factor and obtain welder cable. low voltage high current used all day long not a problem. as for volt drop will not come into the equation as long as all connections are good and tight including any lugs may use
sutol
Any cable suffers voltage drop over given lengh.
If you plugged say three of Halfords extension leads into each other and tried to use your electic drill say 60 to 80 mtrs away then the drill would not work properly if at all. No power see....voltage drop....cable not heavy enough :D
changingman
You are correct there,and i just happen to have a battery relocation kit with external batery cut off switch minus the cables up for grabs.
Its fitted in one of my track weapons but im not going to need it,so drop me a pm if youre interested.
cheers
Liam
gizzmo
oh so next time i wont to drill a hole ill make sure i do it right next to a sub station as to make sure it works 80m 0f.75mm 3183y flex would probably drop 3volts 2m 0f 35mm multi 0.01volt
sutol
whats your drill? say 1800w? if the flex was 2.5mm2 (about 18mV/A/M) then at 80 meters you would get 11.2 volt drop so .75 flex would drop a hell of a lot more.(as the CSA decreses the resistance per meter increases)
