205mattgti 0 Posted December 18, 2006 help i ahve a pug 205 gti with a dealer fit sunroof (not a vacuum one) and it leaks really bad when it rains but cannot find the drain holes to check to see if they r blocked has anyone else got one of theses sunroofs that can help cheers matt Share this post Link to post Share on other sites
Richie-Van-GTi 70 2 Cars Posted December 19, 2006 check its not the ariel as these give same symptons. Share this post Link to post Share on other sites
205mattgti 0 Posted December 20, 2006 check its not the ariel as these give same symptons. its deffo not the ariel have replaced the base and resealed. anymore ideas Share this post Link to post Share on other sites
trogboy 17 Posted December 20, 2006 Soory for sounding patronising but have you cleaned up the rubber seal where that thge flass sits on. Every so often mine gets a tiny bit of crap on it which causes the sunroof to leak when it rains. Also if your sunroof is a dealer fit you may find that the drain points are not connected to any drain tubing which shoukld run down to the sills with the effect that water will drain onto the top of the head lining. This is also the case in my car, so when it leaks the water collects in the rubber trim that runs around the plastic of the sunroof fitting and butts up against the headlining. Pulling down on one corner of the rubber trim when it is raining really heavily is like tipping a watering can all over your lap. Tankfully cleaning up the glass and the rubber seal cured my problem. HTH Share this post Link to post Share on other sites
205mattgti 0 Posted December 30, 2006 i ahve tried everything now and my sunroof is still leaking anymore suggestions Share this post Link to post Share on other sites
welshpug 1,622 Posted December 30, 2006 checked the drainholes? Share this post Link to post Share on other sites
205mattgti 0 Posted January 1, 2007 i cant find any drain holes i ahve removed bits of the sunroof but cant find any has anyone got a pic of where they r located cheers matt Share this post Link to post Share on other sites
welshpug 1,622 Posted January 1, 2007 not sure how this sunroof fits, if its like an AX theyll be under the glass at the front and rear corners of the aperture. Share this post Link to post Share on other sites
