PugAddict 0 Posted December 18, 2006 Take a look............. http://i78.photobucket.com/albums/j110/dalesen/100_0018.jpg http://i78.photobucket.com/albums/j110/dalesen/100_0017.jpg What a state lol I'm having problems with running my GTi for longer than 10mins or so having just rebuilt the engine. Just done a big old SEARCH through old posts and it seems this plug may well be the place to start!! I understand (courtesy of one of Grahams old posts) that these wires are: Starter solenoid - Oil pressure sender - Low oil pressure stop switch - Alternator field wire - Water temp - Water temp warning switch - Oil temp switch - .....BUT WHICH COLOUR CORRESPONDS TO WHICH WIRE? And which two am I missing? I've bought these to help me in my plight, any tips on fitting them? http://i78.photobucket.com/albums/j110/dalesen/100_0025.jpg Cheers D Share this post Link to post Share on other sites
easypug 0 Posted December 18, 2006 1. Reverse light (wire 52, brown) 2. Reverse light (wire 53, purple) 3. Coolant light (wire 47, yellow) 4. Coolant meter (wire 47a, red) 5. Alternator (wire 7a, brown thin wire) 6. Oil pressure meter (wire 30, lilac) 7. Oil temp meter (wire 30a, white) 8. Oil pressure light (wire 30b, grey) 9. Switched positive (wire 2, light blue) Taken from here. Share this post Link to post Share on other sites
Anthony 1,003 Posted December 18, 2006 That's the wrong plug Dave - that's the one in the drivers footwell... Share this post Link to post Share on other sites
easypug 0 Posted December 18, 2006 I knew that.... ahem... Maybe i should try reading the whole thread first Share this post Link to post Share on other sites
welshpug 1,735 Posted December 18, 2006 those are the same connectors as I got earlier this year, out of interest where did you get them and how much for? try a search under "brown multiplug" Share this post Link to post Share on other sites
PugAddict 0 Posted December 18, 2006 welshpug: Just done a big old SEARCH through old posts and it seems this plug may well be the place to start!! I got the Superseal parts from a local motor factors place in Milton Keynes (Motorserv) for the tidy sum of £13. Easypug: Cheers for your help, it's the thought that counts Can anyone break down my 7 wire multiplug in a similar way so i know which colour corresponds to each of these: Starter solenoid - Oil pressure sender - Low oil pressure stop switch - Alternator field wire - Water temp - Water temp warning switch - Oil temp switch - Cheers guys Share this post Link to post Share on other sites
PugAddict 0 Posted December 20, 2006 Can anyone shed any more light on which wire is which? Share this post Link to post Share on other sites
easypug 0 Posted December 20, 2006 You could just follow them from the plug to where there located on the enigne. Should be fairly straight foward... Share this post Link to post Share on other sites
futura 3 Posted December 20, 2006 (edited) Hope that helps a little: From the right on the new connector: pin1=Brown=7A pin2=White=not readable pin3=White=30A pin4=Grey=50A (I think) -- original pin5=Blue or green=46 is unwired on pic pin6=Yellow=47 pin7=Red=47A If you don't already have some get proper ratchets to fit the connectors. Check that you insert the pins the right way to ensure they are secured once in. Once all pins are in, slide down the red plastic bit clamps the pins in place. You may need to push hard when plugin the male and female together. Once fitted it looks like this Edited December 20, 2006 by futura Share this post Link to post Share on other sites
travill 0 Posted December 20, 2006 the starter solenoid is blue! theres one of them Share this post Link to post Share on other sites
pug_ham 245 3 Cars Posted December 21, 2006 AFAIK in order, pin 1-7; 7A; Brown, Alternator. 30A; Orange, Oil pressure switch. 30R; White Oil temp sender. (Oil temperature sender wire is white(ish), sheathed & has a ring terminal on the end so it can't be mixed up.) 30B; Grey, Oil pressure sender. 46A; Blue, Starter solenoid (usually thicker than the rest). 47; Yellow, coolant temp switch. (bigger one at back of thermostat housing iirc) 47A; Red, coolant temp guage sender unit. Graham. Share this post Link to post Share on other sites
