Guest santos2001uk Posted November 20, 2006 (edited) im looking for some, seen a few diesel 205's at the local scrappy. will these fit my 1.6 gti?? Edited November 20, 2006 by santos2001uk Share this post Link to post Share on other sites
sonofsam 5 Posted November 20, 2006 Diesel and 1.6 GTi driveshafts are the same. 1.9 GTi driveshafts are different. Share this post Link to post Share on other sites
Guest santos2001uk Posted November 21, 2006 Diesel and 1.6 GTi driveshafts are the same. 1.9 GTi driveshafts are different. thanks a million for that dude, appreciated. next question, will a 306 diesel box go on the xm or could i change the internals into my 1.6 box?? ive been offered one mad cheap. il have a search too but im not hopefull Share this post Link to post Share on other sites
sonofsam 5 Posted November 21, 2006 I take it you found This OK:D You will need a different clutch btw for your xm turbo? if thats what I think your planning? Share this post Link to post Share on other sites
Guest santos2001uk Posted November 21, 2006 (edited) I take it you found This OK:D You will need a different clutch btw for your xm turbo? if thats what I think your planning? i saw that yea. so it means i can use one with another clutch? or that i cant because the 306 box because its a pull instead if a push.?? il stick to the 1.6 idea till im richer.. and yes i think il be swingin one in at the weekend if i get an engine mount in time.. Edited November 21, 2006 by santos2001uk Share this post Link to post Share on other sites
welshpug 1,735 Posted November 21, 2006 doesnt matter what box you use, just use the relevan gearing. the Pivot points for both types of clutch mechanism are in the same place so its just a case of swapping the release lever over and some of the cable brackets. Share this post Link to post Share on other sites
pug_ham 245 3 Cars Posted November 22, 2006 Fitting a box from a 306 or XM into a 205 will mean that a selector arm needs swapping so you can select any gears, this has to be done with the box off the car & with care so the shaft doesn't drop causing you to loose a few gears. A search should bring up some methods as its been done before, both successfully & un-successfully. Graham. Share this post Link to post Share on other sites
