matt205xs 0 Posted November 13, 2006 Is having the PAS rack an mot failure if its not connected, (its running as a maual rack but still has ram connected) thanks Share this post Link to post Share on other sites
welshpug 1,622 Posted November 13, 2006 remove the ram, should make things a bit easier on the arms! Share this post Link to post Share on other sites
jim21070 2 Posted November 13, 2006 I second the ram removal. Not a difficult job. It'll pass the MOT fine provided there are no leaks and all of the PAS gear (pump, pipework etc) is removed. I think it would pass OK without removing the ram but the MOT tester may be a little unhappy. Still, you could always bluff it and say it was a steering damper... Share this post Link to post Share on other sites
Anthony 1,000 Posted November 20, 2006 Is having the PAS rack an mot failure if its not connected, (its running as a maual rack but still has ram connected) With the ram connected I would say that it would fail, yes, atleast if the tester spots it anyhow With the ram removed it will usually pass fine, but there's been a couple of people who've found a particularly harsh tester who have failed the car anyway - something suitable to cover the holes where the PAS pipes once connected should be enough to prevent this though. Share this post Link to post Share on other sites
inferno 1 Posted November 20, 2006 My sorento had everything removed but kept the pas rack. the tester, who would normally let me go with adviserys and a promise to fix it, decided the steering was too heavy. even though this was decided after taking my car out on the road (which they are not suppose to do), and me proving reverse parking was a doddle with one arm obviously i got a second opinion and they agreed it was fine.maybe as i had 10 months left he decided he couldnt be bothered with the paperwork! Share this post Link to post Share on other sites
