gtimon 0 Posted November 6, 2006 A few of questions on a 205 1.9GTI. 1) How do you guys check your Fuel pressure and what do you use to test. 2) As I'm going to use my 205 for Track days and hill climbs etc., I've seen some use 309 bottom wishbones. What benifits are there in using them. 3) Is the Torsion bars from a 309 GTI or a 205 Van any different. Share this post Link to post Share on other sites
sonofsam 5 Posted November 6, 2006 #1 - I guess you would have to use one of These to test the pressure at the rail.What is your reason for wanting to test it? #2 -There are specific sub forums for this kind of qusetion.That subject has been covered many times now;) #3- As above, but basically YES.They are different. Share this post Link to post Share on other sites
gtimon 0 Posted November 6, 2006 Thanks Sonofsam, The reason for asking about the fuel pressure, is that it hunts badly and smells very rich, Hot or Cold. The previous owner has fitted a 4 branch exhaust manifold, whether thats a reason why its rich, I don't know. I know that the pressure should be approx. 3 bar. Now I'm getting more into using the site, and found that a late van has 21mm tbs. Thanks again Share this post Link to post Share on other sites
smighall 1 Posted November 6, 2006 A few of questions on a 205 1.9GTI. 1) How do you guys check your Fuel pressure and what do you use to test. Why? I guess you need to T into the fuel hose and use a fuel pressure gauge. 2) As I'm going to use my 205 for Track days and hill climbs etc., I've seen some use 309 bottom wishbones. What benifits are there in using them. They give a small amount of negative camber, so give you a little more grip in the bends, and more even tyre wear. 3) Is the Torsion bars from a 309 GTI or a 205 Van any different. Yes they are different, but then the whole 309 beam is different. Oh and as said above, try a search, all of this has been on here many many times, and are answered in great detail. Share this post Link to post Share on other sites
welshpug 1,628 Posted November 6, 2006 ecu engine temp sender Share this post Link to post Share on other sites
sonofsam 5 Posted November 6, 2006 Or possible o2 ( Lambda ) sensor if it had/has one? Share this post Link to post Share on other sites
gtimon 0 Posted November 6, 2006 Thanks for your replies. My next question would be where is the Temp sensor for the ECU located if fitted. Also having a Fluke multi- meter, what sort of readings should I expect to find or is there another method apart from fitting new if missing. Thanks Share this post Link to post Share on other sites
sonofsam 5 Posted November 6, 2006 Results of a search under 'ECU temperature sensor' Share this post Link to post Share on other sites
taylorspug 7 Posted November 6, 2006 (edited) The ECU temperature sensor is the blue electrical plug sensor which is screwed into the housing just behind the thermostat, underneath the distributor. Obviously it will have an electrical connector plugged onto it. Have a search regarding testing the sensor, as i cant remember the resistance values the sensor is meant to have at different temperatures. But yes it is testable (not sure if thats really a word...) The sensor is only around £10 from GSF IIRC. EDIT: Beaten to it with the search thing! Edited November 6, 2006 by taylorspug Share this post Link to post Share on other sites
