petesy71
Poor Idle And Air Leaks
petesy71
hi, i've been reading a lot of posts on idling problems, and one mentioned the screw holding the oil filler to the inlet manifold. i had a look today and discovered this hole and was wondering is it the one that was mentioned?
with the engine running i can hear air rushing into this hole,however when i cover it up the car stalls, leading me to think that it's something else.
any help much appreciated,thanks, pete.
if the throttle stop or air screw have been adjusted to compensate for the airleak it will stall when you remove the leaf, stick a suitable bolt in it and unsrew the air screw on the throttle body to achieve a suitable idle speed.
You may well find that you need to adjust the air flow meter a little to compensate as it would have been adjusted higher to compensate as well.
petesy71
thanks welshpug, is the afm easy to adjust?
yes, but best to leave it till you find a friendly garage with a gastester, its just a 5mm allen key.
basically set the throttle to spec, then adust air screw till its idling at roughly 900 rpm, then set afm. (CO% at idle should be 1.5 but anything up to 3% is acceptable for MOT purposes, lower than 1.5% and itll be a bit lean, higher and it'll be a bit rich and thirsty)
petesy71
thanks a lot for the info mate, pete.
