brianthemagical 1 Posted October 24, 2006 (edited) i'm looking into fitting/making the above. i was thinking just a cylinder and the a bar as the lever. confused as to what cylinder to use. did a quick searsh and reservoir-less MC's were mentioned. is it just a case of plumbing the brake line into the inlet and out of the outlet and having functioning brakes still? any ideas where a cheap/ second hand one may be found i.e oe on any cars? what about clutch slave cylinders? can the orgional compensaters be used instead of an aftermarket bias valve? thanks for the help. Edited October 24, 2006 by brianthemagical Share this post Link to post Share on other sites
RossD 43 Posted October 25, 2006 i'm looking into fitting/making the above. i was thinking just a cylinder and the a bar as the lever. confused as to what cylinder to use. did a quick searsh and reservoir-less MC's were mentioned. is it just a case of plumbing the brake line into the inlet and out of the outlet and having functioning brakes still? any ideas where a cheap/ second hand one may be found i.e oe on any cars? what about clutch slave cylinders? can the orgional compensaters be used instead of an aftermarket bias valve? thanks for the help. Is this for a track/rally car, as hydraulic handbrakes are not legal for road use in the UK Share this post Link to post Share on other sites
Butler 0 Posted October 25, 2006 either run a seperate lever or get the same lever to pick up the hydraulics and cables, which I have done and MOT is fine. Share this post Link to post Share on other sites
Ryan 99 Posted October 25, 2006 hydraulic handbrakes are not legal for road use in the UK They are, as long as they are either on a seperate hydraulic circuit, or have a mechanical backup. If you leave the existing handbrake cables in place, but adjust them so that they are just slack enough not to do anything unles you loose hydraulic pressure then they are fine. Share this post Link to post Share on other sites
brianthemagical 1 Posted October 25, 2006 it will be for a road rally car. the hydralic handbrake will be a non-ratcheting type seperate from the cable lever. Share this post Link to post Share on other sites
