brianthemagical 1 Posted October 24, 2006 interested in doing the above, couple of Q's. is it just a case of getting some threaded rod, cutting it to the right length, screwing it in then getting some suitible nuts? i would have thought the studs would move when the nuts were put on. thanks. Share this post Link to post Share on other sites
boldy205 74 Posted October 24, 2006 you would have to fix the studs onto the hub with weld or somthing. Share this post Link to post Share on other sites
brianthemagical 1 Posted October 24, 2006 sound, that though crossed my mind but i didn't think it was that simple. thanks. Share this post Link to post Share on other sites
boldy205 74 Posted October 24, 2006 im not totaly sure it is! i know Skip Brown do a conversion kit,have a look on their website/phone them up (allways v helpfull!) Share this post Link to post Share on other sites
Ryan 99 Posted October 24, 2006 Threadlock is enough to hold the studs into the hub. The bolts don't need to be done up to 1000lbft or anything like that so the studs should stay in fine. I'm not sure about using threaded bar, is it strong enough? The threads in the hub are M12x1.25 which is a wierd size so you'd probably have a hard time finding threaded bar in that size anyway. Share this post Link to post Share on other sites
pug_ham 242 3 Cars Posted October 25, 2006 Skip Brown use the Peugeotsport studs conversion. The bar need's to be heat treated for use as studs, normal mild steel bar isn't strong enough for this imo. You'd have to buy the flat faced nuts so you might as well get a full proper kit. Graham. Share this post Link to post Share on other sites
brianthemagical 1 Posted October 25, 2006 i realise that i need something stronger then mild steel, just not sure what and didn't want to go into detail too much on materials. as regards to the nuts i think i've got a catologue somewhere with different wheel nuts in so that was another piece of the puzzle. thanks for the help, i think buying the kit will probably be best. Share this post Link to post Share on other sites
Hilgie 16 2 Cars Posted October 25, 2006 Using a threaded bar and cutting that to size is a real bodge and dangerous too. Just buy a complete stud conversion package and you'll immediately notice the difference. Share this post Link to post Share on other sites
