Jonmurgie 2 Posted October 23, 2006 Can someone just indentify this sender please, I believe it's an Oil Pressure sender from an Mi16 but it MAY be the Oil Pressure Light (i.e. low pressure) sender... Cheers Jon Share this post Link to post Share on other sites
welshpug 1,626 Posted October 23, 2006 give it a very light clean on the flats, there should be some ID numbers on it. Share this post Link to post Share on other sites
Jonmurgie 2 Posted October 23, 2006 Will do, though there is an obvious difference between the Oil Pressure Gauge sender and the Oil Pressure (low) sender as pictures here: Question is, which is which?! Share this post Link to post Share on other sites
Normski 1 Posted October 23, 2006 It's not the gauge pressure sender from a Mi16 and it's not the same as the pressure switch on my Mi (mine has a green plastic cover. But it does look like a low pressure switch. The bigger one is the gauge pressure sender. Share this post Link to post Share on other sites
Jonmurgie 2 Posted October 23, 2006 So it must be the low pressure warning light sender then... oops, advertised it as the pressure gauge sender! Share this post Link to post Share on other sites
pug309twin40s 1 Posted October 23, 2006 yep thats the low oil pressure switch thats usually on 8v engines. Share this post Link to post Share on other sites
Jonmurgie 2 Posted October 23, 2006 8v you say... I would have thought it didn't matter if it were 8v or 16v?! Share this post Link to post Share on other sites
B1ack_Mi16 67 Posted October 23, 2006 8v you say... I would have thought it didn't matter if it were 8v or 16v?! It's on all XU9 engines and is as you say for the oil-pressure warning light. Share this post Link to post Share on other sites
