brianthemagical
Bolt Specs?
brianthemagical
i'm after the dimentions of the bolt that holds the bottom of the alternator tensioning braket on a power steering d6b. the pug computors don't have it and the online parts site doesn't have it either. any help would be greatly appretiated. thanks.
ummmmm, cant figure out which bolt it is youre on about, any chance of a piccy? as IIRC it may be the same as a bolt on a derv that ive been working on!
brianthemagical
click. the arrow is pointing to the bolt hole on the alternator tensioner braket. thats the one. thanks.
Ryan
It's a standard M10, 20-25mm long iirc.
brianthemagical
thanks.
M10? Sure you don't mean M8?
It is on the non pas 8v's.
Graham.
Ryan
It doesn't bolt onto the front of the block like on the non-pas models. It goes through a threaded hole in the corner of the end cover like on the mi16. I'm fairly sure the bolt from the non-pas setup is too small.
I'm pretty sure it was M10, but I'll double-check later when I get chance...
Ryan
It's definitely M10 on the mi16 (it's only listed on the 309gti16 page though from what I can see).
Searching for the part number doesn't come up with a match for the 205 though, so it could be M8 or M10...
brianthemagical
thanks for the help. at least it's some where to start. bolts don't cost that much so trial and error is the way. thanks again.
