matt205xs
Wiring Diagram For Rev Counter
matt205xs
can someone draw me a diagram on wiring the rev counter up?
thanks
M@tt
well its just wire number 112 that goes from the coil to one of the connectors that plugs into the back of the instrument cluster. You'll find its usually the green shielded wire.
Edited by M@tt
matt205xs
does it go via fuse box or relay ? and connect to which connection on the coil?
M@tt
No fuse or anthing and goes directly from the negative side of the coil (old cylinder type of coil with connectors on the top of it) or will just be in the 1 main plug on the later style ones through the bulk head and up to the intrument cluster to one of the pins on one of the 3 plugs on the back of the instrument cluster.
matt205xs
sounds easy enough, cheers
The rev counter has some links with a fuse #1 iirc, if that blows the the rev counter stops working along with losing the dash lights but the wire doesn't run through the fusebox afaik.
On the inlet mounted coil plug it goes to pin #1 which also has a green shielded wire in but wire 112 is a blue/ grey colour.
Graham.
cybernck
graham> correct, but that's only the +ve supply for the rev counter and can be taken from other places.
matt205xs> do a search as we've had a detailed conversation (with schematics) very recently.
