MikeHunt79
Clear Rear Light Lenses?
MikeHunt79
I;ve currently got phase 2 lights on the rear. I was wondering where I could get rear lenses that are the same as stock lenses but with out the red filter? I'd like the whole lens to be clear, or maybe lightly smoked like the indicator part of the lens is.
Wes
you can get them from abc design but they are phase 1 only.
MikeHunt79
That's good to know... I guess phase 1 lenses will not physically fit onto a phase 2 reflector will they? I might be able to get a phase 1 reflector, but it's a lot more hassle with rewiring and things...
EDIT: Does abc design have a website or anything like that with more info or a piccy? I did a quick google, but only came up with ford focus bits :P
Edited by MikeHunt79
Wes
you will have to change the backing plates and reverse light as the bulb layout is different.
Guest Pugw0t
they look ok but personally i'm a fan of boring old standard ones :P
MikeHunt79
That looks good. I want to go for a similar look, where the lights match the colour of the car, but my 205 is graphite greay, so slightly smoked lenses would be nice and stealthy.
I don't think phase 2 reflectors would work too well tho, so if I come across a phase 1 reflector, I might give this a go... Even so, standard phase 2 lights will do for now. :P
max0
ive seen a few cars with what looked like smoked lights, which had there girl friends tights over it so you can take it off and go back to standard, didnt look to bad.
ada205
I don't think phase 2 reflectors would work too well tho, so if I come across a phase 1 reflector, I might give this a go... Even so, standard phase 2 lights will do for now. :(
Think these might be what your looking for mate..CLICKY You can get them here from Autofive
kevcomdude
I used go-fast stripes in a similar coulur repeatedly one stripe on, one off going down the light casing on mine to hide the hideous colours of the rear lights.
MikeHunt79
Well, it does sound like a lot of hassle... I might leave it for now, as the mot i coming up soon, and I don't want to have more wires hanging out than there currently is! If there were some phase 2 clear lenses, it would be a lot easier. :) Cheers for the help anyway... I'll be sure to post more info on my led conversion when it's done. LED's = brighter, use less power, and the LED lasts for over 50,000 hours, which they'll probably outlast the car, as sad as it may be.
Guest Tom Dimma
eccosse do them ive got the smoked rear lenses on mine
TaffyTim
Ive alway been a fan of the orig look too, but when i got my pug they came with these smoked rears which i quite like now. Only thing is that I dont know where the past owner got them from. If this is what your after I can send him an email to find out.
Guest Tom Dimma
they are the eccosse ones i have the same i got mine from ebay
MikeHunt79
They look good... I've got some clear ones now, but they won't be on there for a while, as i'm waiting for all my LED bits to come thru the post. :)
