Guest TonySmiff Posted October 5, 2006 Have done some searching but cant find anything...... Can i get the ecu unlocked to do away with the immobiliser or can i wire in the arieal around the ignition switch etc and use the immobiliser? Using the 406 ignition barrel and key i suppose due to the chip in the key? Tony Share this post Link to post Share on other sites
sonofsam 5 Posted October 5, 2006 Hi Tony. You sure you searched , there is atleast two pages of info on unlocking ECU's and were to get it done. Not heard of your aeriel idea though. Yes you can get it unlocked, but it costs a fair amount! Sam. Share this post Link to post Share on other sites
Martin@PRD 0 Posted October 5, 2006 Camco in warrington will sort that out around £200 Share this post Link to post Share on other sites
sonofsam 5 Posted October 5, 2006 Mine was £145 including VAT and a refurb! www.ecu-doctor.co.uk Share this post Link to post Share on other sites
smighall 1 Posted October 5, 2006 Mine was £145 including VAT and a refurb! www.ecu-doctor.co.uk Snap However, if you have all of the wiring and components of the immobiliser there's nothing stopping you wiring that in and just using it as is. Share this post Link to post Share on other sites
jonnie205 1 Posted October 5, 2006 Unplug ecu with engine running, this will permanently unlock ecu as long as it never sees transponder box again Share this post Link to post Share on other sites
Guest TonySmiff Posted October 6, 2006 Unplug ecu with engine running, this will permanently unlock ecu as long as it never sees transponder box again I know this will work on the early 406's with key pads (disconect the key pad and ecu wont lock again) but this is a d9 406 on a t-reg would this work the same? To wire in the standard immob looks like would have to wire in the 406 Bsi as code is received by the bsi from the key and then the bsi unlocks the engine ecu. Going to look into the boxer coded key system as they have a small immob ecu seperate to the bsi which i may be able to adapt but failing that will get it unlocked. Both seem like to much hassle Share this post Link to post Share on other sites
jonnie205 1 Posted October 6, 2006 Yes it will work on any age 406 or 306 ta Share this post Link to post Share on other sites
Guest TonySmiff Posted October 6, 2006 Yes it will work on any age 406 or 306 ta Brilliant thanks jonnie thats easier and cheaper than the above Share this post Link to post Share on other sites
