Ritmo
No Indicators And Hazard
Ritmo
Hi
my gti started happening problems over the last couple of days, when driving the indicators would some times come on and the petrol guage is going mental!! :mellow:
Now with the engine running the indicators and hazards dont work but when you turn the engine off they work but the petrol guage moves in time to the indicators, also when the brake pedal is applied the petrol guage does strange things!!
The engine is running but when you accelerate its misfiring and the ptrol guage is showing empty.
Could this be an earth problem? or something more sinister :ph34r:
Its a 1.6 gti with 135k on the clock if this is relevant, any thoughts or suggestions are welcome.
Thanks in advance
Grim.Badger
Sounds like an earth problem, or at an outside chance some wires may be touching each other. Check the yellow earths under the headlights first as the indicators earth there.
sounds like a bad earth to me, there is one behind the pass side rear light cluster that is for the rear lights, fuel pump and fuel gauge so I'd check that first.
Ritmo
thanks guys will look at this at the weekend and hope i can sort it out
Electrics allways an unknown!!
Ritmo
Hi guys
it was the earth block at the rear light as you suggested jackherer, when I tried to take the plug off the earth block the whole thing came off in my hand all rusted away. I have reconected the block on to a solid part of the body and connected the earth wire! everything back to normal :)
The car runs better now, so it must have been a problem for a while! the petrol gauge is showing the correct amount of fuel, lights are brighter and the revs are not fluctuating as much.
I can only wonder if everyone did this 10min job with their gti's how many problems it would solve!
thanks for the good advice guys
Ritmo
nice one :)
if its running better now it must have been the fuel pump running slowly before...
Ritmo
Hadden't thought of that but yes it could have been the fuel pump running slow or pulsating when the lights, indicators, heater was switched on!!
I had some burnt wires in the engine bay as well, it was the wires to the fog lights, the prevous owner had replaced them with an aftermarket set of fog lights and wired them to the main beam of the head lights using a relay!! I was lucky it didn't catch fire!
The car is 16 years old and the wiring is getting a bit tired just trying to fix everything as it goes wrong to keep the gti alive.
Ritmo.
