ORB
Manifold
ORB
Dont know if you lot remember me saying i had a bit of a crack in my Exhaust manifold.
Well, i got around to taking it off yesterday and took it to work today to get it welded up.
Here is the extent of the crack
Just thought you may want to see it?
Full manifold:
http://img.photobucket.com/albums/v290/orb...81/P8250107.jpg
Close up
http://img.photobucket.com/albums/v290/orb...81/P8250106.jpg
the pics dont show the full extent of the crack, but its a good one.
Will post up some more when i get round to welding her up :P
jim21070
Orb,
Did you have the proper knitted "scouring pad" manifold to down-pipe gasket fitted as from what I see in the picture it looks not. I also spot what looks like the remains of exhaust putty there.
If that was the case then the exhaust would have leaked terribly from that joint and much worse than from the crack.
hengti
how're you going to weld it?
v difficult to reliably weld cast iron unfortunately :blush:
ORB
Yeah, it had the correct type of manifold gasget, just the pic was cack!
also, there was no putty.
The crack will be arc welded, i am ok at it and have done a fair few in the past :blush:
