acox99 73 1 Cars Posted September 11, 2006 I was looking at getting solid engine mounts, found a solid lower mount, but can you get solid top mounts as well? or are Group N rubber top mounts ok? its for a sprint car. what is everyone using? Share this post Link to post Share on other sites
boombang 2 Posted September 11, 2006 The BBM stuff is hard enough for any use - Grp N spec all round with uprated lower mount. Share this post Link to post Share on other sites
hengti 2 Posted September 11, 2006 can you actually get solid mounts? wouldn't have thought they'd be a good idea, even in a compo car - you'd just break things - ? Share this post Link to post Share on other sites
boombang 2 Posted September 11, 2006 I've seen a solid ally lower mount - in car it honestly felt the same as a BBM lower but they aren't usually made solid for a reason - to give a slight cushioning effect. BTW I think the guy made it up on a lathe rather than buying it! Share this post Link to post Share on other sites
Jonmurgie 2 Posted September 11, 2006 http://www.bakerbm.com/ Share this post Link to post Share on other sites
acox99 73 1 Cars Posted September 11, 2006 Cheers, just placed an order Share this post Link to post Share on other sites
Rippthrough 98 Posted September 11, 2006 I've seen a solid ally lower mount - in car it honestly felt the same as a BBM lower but they aren't usually made solid for a reason - to give a slight cushioning effect. BTW I think the guy made it up on a lathe rather than buying it! There are 2 bushes in the lower mount though, so the other should provide some cushioning effect. Share this post Link to post Share on other sites
boombang 2 Posted September 11, 2006 yeah that'd true. Looked pretty hardcore though but as I said it was really no worse than "grp A" spec. Share this post Link to post Share on other sites
Jonmurgie 2 Posted September 11, 2006 I believe Stew does 2 versions of the bottom mount, one similar to the PugSport GrpN and one a little stiffer (which is what I now have) Share this post Link to post Share on other sites
acox99 73 1 Cars Posted September 12, 2006 spoke to stew this morning, and thats what he is sending me. Share this post Link to post Share on other sites
