markw 1 Posted August 19, 2006 hi just wondering what size master cylinders you guys are using mine is standard (and old) and i dont like the long pedal travel (on a 205 1.9) since fitting the gti 6 brakes Share this post Link to post Share on other sites
Jonmurgie 2 Posted August 19, 2006 I think i does vary a little but if your not liking the 205 MC then you want to get the 406 MC... try a search and you will find some info on it Share this post Link to post Share on other sites
smckeown 2 Posted August 19, 2006 i put the 23.8mm M/C with gavs car and the brakes are spot on. Nice and firm pedal. Share this post Link to post Share on other sites
Jonmurgie 2 Posted August 19, 2006 That's the 406 one isn't it? Share this post Link to post Share on other sites
markw 1 Posted August 20, 2006 thanks lads will check gsf tomorrow Share this post Link to post Share on other sites
Phil 0 Posted August 21, 2006 406 cast iron non abs M/C on mine, works a treat Share this post Link to post Share on other sites
Matt Holley 11 Posted August 26, 2006 406 cast iron non abs M/C on mine, works a treat Did you have to adjust the rod on that to stop to brakes binding or is a straight swap? I fitted a set of gti6 calipers today and Im sure the pedal is longer on this one than my last 205 with the same set up (still using original mc) and would like to get the pedal back to normal. Share this post Link to post Share on other sites
