Woosey
Leak Into The Cabin.
Woosey
Im really baffled, water appears in the passenger side only, under the carpet and pools in teh bottom right, its not the door seal, and its not the heater matrix..... any other ideas where this water is coming from?
thanks
chris
Edited by Woosey
GLPoomobile
Im really baffled, water appears in teh passenger side only, under the carpet and pools in teh bottom right, its not the door seal, and its not the heater matrix..... any other ideas where this water is coming from?
thanks
chris
It might be the collective tears from all the members who are about to cry 'DO A SEARCH'! :)
Seriously, this has been discussed recently, at least once.
Woosey
At sorry, ill give it a whirl
thanks mate :lol:
d-9
What GLpoomobile was trying to say was "I know the answer but I'm not going to tell you nah nah :)"
Windscreen seal is the most likely culprit, if its damp at the front of the passenger footwell.
Paintguy
I found 2 areas on mine that were letting water in; one was the windscreen seal, and the other was water running inside the door, and out through the gap between it and the inner trim panel.
Plenty of bodyline to seal up the door holes sorted the latter :)
