1.9er
Leaking Sunroof
1.9er
During the heavy rain last sunday,water started seeping through from around the area of where the sunroof handle is located.Would some form of sealant be the best way to deal with this?
steve@cornwall
You can loosen the screws and put silicon in before retightening- or I believe original washers are available from pug cheaply
the original fibre washers are something like 27p from pug dealers, or you can get identical washers from plumbing suppliers for 1-2p each (in large bags, you can then sell the rest on ebay for £££s each to crazy people)
NOsMAN
Just got 2 rubber o rings from 205 parts and replaced the knackered ones.Leak fixed :)
Guest CJG122
O-rings indeed should do the job. I had the same problem. Got some thick rubber o-rings and filled the top of the screw on handle with silicone for double protection. Dont crack the glass when screwing back on - that would not be good.
Chris
arry
I need one of the bolts, as one of them has gone walkies out of mine. Might pop over the dealership now as it happens.
How do they unscrew exactly? There's no head on them is there?
nick
Mine was leaking from the sunroof external trim screw holes, it used to fill the interior light up with water.
Silicone to the rescue again!
Nick
they unscrew from below, on the plastic handle there are two sqaure covers that need to be pried off to access the screws.
arry
Cheers B)
arry
Just been to Peugeot - excellent service as always from them B)
2 washers at 25p each - part number 694875
1 sunroof screw at 55p - part number 691282
the expensive bit was the nut for the top, £3.96 :) but they had to order that in. But it will be here tomorrow! 842419
Apparently once they've sold out of the screws and washers they're never going to restock, so if you're missing bits - get in there quick :D
Edited to include part numbers, if they're of use to someone :)
Edited by arry
feb
Thanks for the part numbers, exactly what i was looking for. Got the same problem as my washers have perished.
arry
No worries :D
Just picked the nut up so I've got all the bits to fit now. Only thing I don't have is star shaped drives so it'll have to wait until I get my tools back from my mate :rolleyes:
