aldo56 0 Posted August 7, 2006 ive just recieved my new 1.9 engine!!!! looks in great nick, the only obvious problem is that the coil is on top of the inlet manifold and different to where my original one!!?! any ideas on how to remedy this problem?? many thanks allan Share this post Link to post Share on other sites
sorr 0 Posted August 7, 2006 Unless you want to change the engine loom I would just buy one of the cylinder shapped coils and put it back in the location used on the 1.6. If you still have the one from your 1.6 use that as it is the same as a 1.9. Share this post Link to post Share on other sites
aldo56 0 Posted August 7, 2006 also, is there any difference between the 1.6 and 1.9: afm? starter motor?? alternator?? ecu?? and if there is, is it 100~% nessasary too change them? thanks again allan Share this post Link to post Share on other sites
aldo56 0 Posted August 7, 2006 thanks alot for the advice, makes it so much easier when you can ask someone thats done it b4!"" Just got to get my hands on a afm and ecu now!! Share this post Link to post Share on other sites
sorr 0 Posted August 7, 2006 The injectors are also different, you need the 'yellow' ones for a 1.9. Share this post Link to post Share on other sites
aldo56 0 Posted August 7, 2006 yeh thanks, ive got the injectors, i think i should be alright now if i get an afm and ecu. thanks again Share this post Link to post Share on other sites
