Miles 331 1 Cars Posted August 7, 2006 Just need to know a simple thing of which wires go into the 2 pin plugs (Blue & Black ones) that plug into the Lambda sensor on the Cat equiped Motronic 205 GTi, Cheers in advance Share this post Link to post Share on other sites
petert 616 Posted August 7, 2006 switched +12V and earth signal and earth Share this post Link to post Share on other sites
Miles 331 1 Cars Posted August 7, 2006 Would you know which pins they go into the std loom plugs thou? I;ve got my 12v and signals sorted out after hunting down the fuse for the heater side of the sensor. Share this post Link to post Share on other sites
petert 616 Posted August 7, 2006 (edited) see page 2 of this thread: http://forum.205gtidrivers.com/index.php?showtopic=58265 It's the same as the 3 row Mi16, less idle motor and knock sensor. Part M848 Edited August 7, 2006 by petert Share this post Link to post Share on other sites
Miles 331 1 Cars Posted August 8, 2006 Cheers for that Peter, Share this post Link to post Share on other sites
cybernck 403 1 Cars Posted August 8, 2006 hope this helps: (both whites to the black connector, grey and black to the blue connector). p.s. don't cut and/or solder the wiring as apparently lambda sensor won't function correctly. hilgert can tell you why more precisely . Share this post Link to post Share on other sites
petert 616 Posted August 8, 2006 That seems kinda odd. When I make Haltech looms I always crimp, then solder the wires to the pins. I certainly haven't had an issue. I would have assumed that when you're only dealing with <1V, every effort must be made to eliminate a voltage drop. Share this post Link to post Share on other sites
cybernck 403 1 Cars Posted August 9, 2006 to put simple, as far as i understood, it's something to do with outside air being drawn in to the lambda sensor through one of the wires in order to compare it to the exhaust gas... as i said, ask hilgie if you want the details . Share this post Link to post Share on other sites
Owain1602 0 Posted August 10, 2006 Yes, it has nothing to do with volt drop. In order for the lambda sensor to compare the oxygen content of the exhaust gas with the oxygen content of the outside air, it must get a sample of both. It get the exhaust sample obviously through the sensor, but only way it can get a sample of outside air is for air to travel down the wiring to the sensor. It sounds mad i know. I was told this on one of the Fuel Injection Bosch course i went on by one of the head training technicians Kevin Crangles. Most lambda wiring is nichrome wire and it doesnt solder very well anyway, the joints might seem ok but infact it cracks quite easily because the solder doesnt actualy bond with the nichrome properly. As you, i used to solder them but i dont anymore :S Share this post Link to post Share on other sites
Miles 331 1 Cars Posted August 10, 2006 Stuck again, I;ve got the black plug sorted, Power 12v + (96) and Earth The Signal and Earth wires are not marked by a number I;ve found out both wires goto the ECU plug, Pins 10 (Green) & 20 (Red) but need to know which connect's to the Black and Grey wires of the sensor Share this post Link to post Share on other sites
Hilgie 16 2 Cars Posted August 10, 2006 Yes, it has nothing to do with volt drop. In order for the lambda sensor to compare the oxygen content of the exhaust gas with the oxygen content of the outside air, it must get a sample of both. It get the exhaust sample obviously through the sensor, but only way it can get a sample of outside air is for air to travel down the wiring to the sensor. It sounds mad i know.I was told this on one of the Fuel Injection Bosch course i went on by one of the head training technicians Kevin Crangles. Most lambda wiring is nichrome wire and it doesnt solder very well anyway, the joints might seem ok but infact it cracks quite easily because the solder doesnt actualy bond with the nichrome properly. As you, i used to solder them but i dont anymore :S I was told EXACTLY the same. It is in the Bosch service books as well. It is the reason all connectors are clamped to the wires instead of soldered. Share this post Link to post Share on other sites
Miles 331 1 Cars Posted August 11, 2006 Any idea's on this?> Share this post Link to post Share on other sites
Owain1602 0 Posted August 11, 2006 If you get really desperate, what you could do if the engine runs is stick something that produces around 1-1.5V, i normaly use a AA battery. Earth the -ve side of the battery and send the +ve side down each wire in turn and watch what happens to the mixture. If you are sending the voltage down the signal wire the mixture will lean off a lot, if you're not nothing will happen. Bear in mind it would have to be hot enough for closed loop. Quite weird the earth for the lambda sensor comes back to the ECU, but there we go, French wiring. Share this post Link to post Share on other sites
Miles 331 1 Cars Posted August 11, 2006 Thats the thing, It's not french wiring it's German, LOL The only thing I normally find wrong is the non French parts Share this post Link to post Share on other sites
Owain1602 0 Posted August 11, 2006 Is it possible for you to do the test i explained above with the car or is it not possible? Its not damaging in any way to the ECU or anything else, it is probably the easiest way without getting PIN data which i dont have at home, Ill have a look in work tomorrow if you like. Share this post Link to post Share on other sites
Miles 331 1 Cars Posted August 11, 2006 I think I;ve worked it out with wiring info from most Pug models, The earth is a 0 volt referance with other sensors going to Pin 10 of the ECU the signal going to pin 20, Started the car up and all seems fine so fingers crossed come emmsion test time Share this post Link to post Share on other sites
Owain1602 0 Posted August 11, 2006 o right, glad you found it. Since you're here and an expert on suspension. What do you recon of the yellow bodied bilstein struts and any idea of price for the front and rear? Thanks a lot, Owain. Share this post Link to post Share on other sites
Miles 331 1 Cars Posted August 11, 2006 Drop me a PM for further info on that, I'll get you a good deal without a doubt Share this post Link to post Share on other sites
