Guest ratty
Cutting Out
Guest ratty
He, iv got an e reg 1.9 205 gti,but recently its been cutting out,when i have to come to a stop,and in the morning it has trouble starting i really need to give it gas,does anyone know what could be up with it?
richard
Clean your AFM and throttle body.
If you havent replaced simple things like rotor arm and dizzy cap. cleaned and regapped plugs to either .8 or .9mm i'd suggest you do this. Just to rule out the basics
Does it do this when idiling (or trying to idle) or is it only when there your stopping abruptly after being on the throtle, if so it may be an air leak somewhere. Your idling speed should be around 1000 (book is 900 iirc) but 1krpm seems to cure a lot of problems.
Theres a screw on the Throtle body, and a allen socket on the AFM, these can be adjusted, (max of 1/4 turn each time you test) but if your not sure what your doing you could end up making it a lot worse.
