mishu
Carbed 1.6 Gti Engine
Guest ashnicholls
What do you mean the gear changes are rough?
dodsworth_gti
think its more me than anything lol!!!
when i cant be chewwed to drive it kinda gets a bit rough lol
every one said idle would be rough but it isnt?!?!?!
Edited by dodsworth_gti
ifcho
If you would be fitting an electric pump in the tank, then you will need to swap your tank for a GTi one.
I have done the 1.1 - 1.6 conversion on my 205 1.1 CJ and there are quite much bits that should be changed.
Don't forget to get a new gearbox lever, as the one you have, when fitted on the BE gearbox, will make first gear go into your dash <_<
Guest ashnicholls
Why????
I used all the same levers and linkages, excepted I did fit a quick shift?
