vince
Brake Bleeding
vince
hi guys,
it has probably been dealt before, but in case you don't know there is a really easy way to bleed your brakes without any helper:
-use a breathing oxygen supply hose.
if you can get one, you will see the hose diameter is exactly what you need, and then, and here is the trick, they are equipped with non return valves, hence you just plug it over the bleed bolt, unscrew it, brake until you don't have anymore air, retighten the bolt, and so on at the 4 corners.
10 to 15 minutes to bleed the 4 brakes, on your own.
now, the question is where can you find such a hose? I don't know... is the answer.... seriously, I get mine from my work. they are provided for portable oxygen bottles onboard aircraft, as spare parts. you may try your chance at your local hospital at your next visit... ;)
hope it helped
vince
you can buy pipes like that from motor factors that are designed for the purpose.
I like your style though ;)
vince
I like your style though B)
ok, then you know... :blush:
who said I hadn't discovered hot water??? ;)
sorry for my "style", I'm doing my best with your language... ;):D
vince
sorry for my "style", I'm doing my best with your language... ;);)
thats not what I meant, I was trying to say I thought it was cool that you had got it from your work instead of paying at a shop :blush:
vince
thats not what I meant, I was trying to say I thought it was cool that you had got it from your work instead of paying at a shop ;)
yes, I understood that after replying... stupid me!
vince "fire first, then negociate..."
Rippthrough
I nick the used ones from hosiptials, they have to chuck them away anyway.
Veero
But you're French, not American :);)
