Grim.Badger 15 Posted July 20, 2006 (edited) My old 205 was a diesel with brand new standard front suspension (shocks, springs, bushes, lower suspension arms) and a 1.9GTi rear beam with new diesel shocks and new sandwich bushes/mounts. It also had refurbished front calipers, 1.6GTi wheels and Yoko tyres. The point is it handled like it was on rails, although with a bit more body roll than the GTi. Would slightly thicker torsion bars and new suspension components give me similar handling in the GTi? Edited July 20, 2006 by Grim.Badger Share this post Link to post Share on other sites
Anthony 1,000 Posted July 20, 2006 Stiffer (GTi, possibly aftermarket) springs should help although if be a bit nose heavy still with the heavy old derv lump up front. Rear beam will be fine if it's a 1.9 item as this'll already have thicker TB's and ARB compared to the original diesel item. Share this post Link to post Share on other sites
jonD6B 0 Posted July 20, 2006 What tyres are you running on the GTI? Share this post Link to post Share on other sites
Grim.Badger 15 Posted July 20, 2006 Stiffer (GTi, possibly aftermarket) springs should help although if be a bit nose heavy still with the heavy old derv lump up front. Rear beam will be fine if it's a 1.9 item as this'll already have thicker TB's and ARB compared to the original diesel item. Sorry didn't make myself clear. I don't have the diesel anymore, I want my GTi to be as sure of itself on the road as my old diesel was and was thinking that to get similar results I'd have to upgrade the GTi torsion bars so that they are stiffer than standard and give a bit more solidness to the rear. Basically: Diesel Front suspension + GTi Rear Suspension = Good drive GTi Front Suspension + GTi Rear Suspension = A bit tail happy GTi Front Suspension + Uprated Rear Suspension = Good Drive? The GTi is running Goodyear Eagle Venturas on the Front and Yokos on the rear, but all are a bit old and I will be replacing with a full set of new yokos when I have the money. Share this post Link to post Share on other sites
