Guest TSL 333
Front Scooshers Barely Working
Guest TSL 333
Battery is fine, washer bottle is full, pressure is crap. Any ideas - could the motor be on it's way out?
TEKNOPUG
probably the pump. They just pull out from the bottom of the bottle. Check the connections for corrosion also. Could also be blockage in the line to the jets.
steve@cornwall
They're pretty crap, so I reckon so! May be worth taking the jets out of the bonnet and seeing that you can blow through them easily- if not a single strand of speaker wire can be twiddled down the jet to clean it
sonofsam
You could always get a pump from a 406 there alot stronger
trogboy
Take out the the pump and see of you've got any cack in the intake.
Then have a look at the tubing - it should be see through so blockages are quite easy to locate.
Pins are also good for the washer jets
Edited by trogboy
Simes
Pump is £12.50 from Pug and the jets are £2.50, Hose about £3 from Halfrauds. I've just replaced it all - what a difference!
Grim.Badger
A 205 pump should easily have enough pressure to run twin jets from Halfords. I replaced my old system a while back and it made a huge difference, especially with the twin jets :D .
Didn't work so well when I transfered it over from my old car for some reason :blink:
Paintguy
Try swapping the front and back pumps around first to see if that cures your problem :blush:
hengti
clean the fluid reservoir and the pipes out as well - they can gunk up fairly quickly
Bono
Not sure how well they would work on 205 but on my 306 i have 307*i think* washer jets which sort of mist the water on instead of just two squirts.
It works wonders, although i'm afraid i can't remember the part number or exactly what car they came off.
Edp
Put your reservoir in the dishwasher, comes up a treat. But dont tell the missus!
Simes
These empty the resevoir in a matter of seconds and are ugly. :blush: The OE parts from Pug are cheaper and you don't have to fill the bottle up so often,
Henry Yorke
I did that on my skip and it is incredible the difference. I also twin jetted from a 306 and spent hours spraying myself whilst doing contortionist manouvers with a pin in my hand!!
sonofsam
That coupled together with a bx spray bar WOULD empty the tank fairly rapidly, but its a big reservoir. Never bothered me filling it up more often.Plus you can remove the jets altogether!
