timmsy19
Bonnet Hinge
timmsy19
Evening all.
had a bit of a problem tonight when i came to lift my bonnet up. the bloody thing has snapped of on the drivers side hinge. the lifter is fine but the bonnet lifts and closed pissed. :P
any ideas what to do? have been thinking bonnet lifters from the 106 as its more of a perminant fix, however how easy would it be to fit the new hinge???
DaveW
when you close it push it down on the dodgy hinge bit it should shut ok, plus they can be a cnut to get if the bolt has snapped off :P
timmsy19
it doesnt close straight so its a pain in the arse at the mo. as i said the bonnet rest is fine and so is the passengers side hinge its just the drivers side which i think the bolt has finally snapped
vern
This happened to my old diesel 205, its dead easy to replace the hinge it is a simple unbolt, bolt, but would advise to get a glamouros assistant to hold the bonnet while you do the swap over, to save any possible damage to the paintwork.
bitchass 205
Evening all.
had a bit of a problem tonight when i came to lift my bonnet up. the bloody thing has snapped of on the drivers side hinge. the lifter is fine but the bonnet lifts and closed pissed. :(
String!!!!!!! :P:(
timmsy19
ive got an assistant so there is the first bit done just need to take a proper look at it and find out how buggered it is
String!!!!!!! :P:(
how would string help???? could try zip ties like evrything else is held on, on a 205
