Henry Yorke
2.0 Turbo - Wastergate Chatter And Dumpvalves
What are Citroen ones blanked off with?
its just a rubber bung on my activa IIRC
sonofsam
Yep just a bung with a metal strap i think, got a spare somewere if you want to try without DV.
Kev-G
both are left hand drive maybe a euro thing?
Not LHD - 406 MC is on the RHS (looking @ the engine bay)....Look @ the wipers in the 2nd. pic.
The engine in our 306 is from a 406 IIRC and has a recirc. DV.
tom_m
heres an XM bay for ya, the boost pipe is running down the battery side of the engine, with the two blanks sticking up.
cybernck
Peugeot or citreon spent hundreds of thousands, possibly millions, developing this engine. And they didn't see the need.
405 T16 has got a complete preparation for dump valve installation,
both VTA and recirculating systems.
i'm pretty sure they haven't fitted a standard plastic Bosch recirculating
valve as T16 is running 1.1-1.3 bars of boost as standard, which is quite
a bit more than the said valve can handle really.
Henry Yorke
So looking at the pics, it seems if you have a 406 engine with the pipe that comes over the top, then you have a recirc blow off valve, whereas if you have a cirtoen engine with the boost pipe down the side, then you don't have one. I wonder what caused this decision? Are there effectively two XU10J2TE engines then, one for Peugeot and one for Citroen? Does it make a difference on what year your donor car was (XM's were earlier than 406's)?
The more questions I ask, the more confused I become and the more grey this whole subject seems to be!
Beware the fog!!
Malachy
Beware the fog!!
no my xantia activa engine has the pipe over the top and no recirc.Maybe to do with year but then why were the older cars designed with the blanking plugs if only the newer ones were getting the recirc?
Edited by Malachy
