DaveK 0 Posted June 26, 2006 Im in the middle of changing the hub carrier and the new one has a very slight play in the part that the wheel bolts to. Does this mean the bearing or cv joint is knackered? Compared it to the old one and the old one is solid, no wobble atall cheers dave Share this post Link to post Share on other sites
pugrallye 0 Posted June 26, 2006 do you have play in the bearing??? assuming it is, then do you have play with or without the driveshaft in and torqued up? Share this post Link to post Share on other sites
DaveK 0 Posted June 26, 2006 its not on the car atm, just checked it before puttin it on should i put it on and tighten it all up to see if its fine then? im pretty sure its play in the bearing Share this post Link to post Share on other sites
pugrallye 0 Posted June 26, 2006 yes you will get 'slight' play in bearing when driveshaft isnt bolted in Share this post Link to post Share on other sites
DaveK 0 Posted June 26, 2006 i can pull the wheel carrier out and in a little aswell Share this post Link to post Share on other sites
ALEX 105 1 Cars Posted June 26, 2006 Does the wheel rumble?If the bearing is failing the noise should be louder when turning. They do have play in them with the Hub nut is off but not much. Share this post Link to post Share on other sites
pugrallye 0 Posted June 26, 2006 is it a new bearing? otherwise does it turn freely in your hand? Think your best off sucking and seeing, bolt it in place and torque up driveshaft and go from there, will only take you twenty mins to fit one Share this post Link to post Share on other sites
DaveK 0 Posted June 26, 2006 yea ill just fit it and hope for the best, its only bout 1mm play so hopefully it will be fine cheers chaps Share this post Link to post Share on other sites
pugrallye 0 Posted June 26, 2006 yeah you will get that cos bearings are in two halves, as soon as you tighten driveshaft it will pull them together removing the play Share this post Link to post Share on other sites
DaveK 0 Posted June 26, 2006 ah ive just compared it to the other side o the car and its the same, superb! Share this post Link to post Share on other sites
niklas 1 Posted June 26, 2006 Does the wheel rumble?If the bearing is failing the noise should be louder when turning.They do have play in them with the Hub nut is off but not much. How much is much? What is ok and what isn't? Share this post Link to post Share on other sites
