Mad Professor
Custom Studs
Mad Professor
Hi All.
I am trying to get hold of or get some custom studs make up.
I need four studs with M12 1.5 Pitch one end and M10 1.5 Pitch the other.
has anyone got any idears?
Thanks.
mbayley77
have you tried a local machine shop? they should be able to make up something like that without any problems.
Mad Professor
I have been into a few local firms.
When I ask thay look at me like I am mad.
This Island is useless.
Pug_101
I might be able to have them made up for you.
Whats lengths each thread, do you need a flange in the middle etc.
Post the details and hopefully by the end of next week you'll have them.
What they for??? if you don't mind me asking
jack biscuit
Hmm, i wonder? Given them a drawing? What are the studs for? Don't studs usually have a different pitch thread on each end?
Mad Professor
I have not got the lengths to hand at this point in time.
I think it probley would be best to have a blank flange in the middle.
This is for my TT manifold, The manifold had been drilled out and helicoiled, I guess someone in the past had snaped a stud, I hate helicoils at the best of times to retaped the manifold to M12 (1.5mm Pitch), A M12 stud will not fit tho the holes in the turbo and I am sure not drilling the holes bigger to fit.
So I tought it would be best to get a stud to suite.
Pug_101
So you'll need high strength material then :)
Not any old mild steel.
Mad Professor
Pass...
StuartE
If you get stuck for somewhere to get these made you could always try these guys.
http://www.nssocketscrews.com/
I've never used them myself but they claim they can make anything to the customers drawing, could be costly but like I say if you're stuck it's worth a try.
M3Evo
Thought manifold studs were pretty s*itty in terms of material generally.
Think I've got an M12x1.5 die kicking about, but only an M10x1.0 but if anyone's got the M10 to lend me I'd happily make them out of mild if you're stuck :rolleyes:
Mad Professor
So far only one firm has replyed to my e-mails / phone calls, and thay want £15 per stud. :angry:
StuartE
Is Mild Steel alright for these then?, if so i'll ask a guy at work who makes stuff.
Mad Professor
I don't know but the recipt from Turbo Technics, say that the turbo manifold nuts are Mild Steel.
Banjo
Just use a Heli coil mate, there very strong.
M3Evo
Wow, suddenly just occured to me that M10x1.5 is the standard pitch so I've got an M10 die here! What a numpty I am!
If you wanna get hold of some 1/2" mild steel bar and post it to me with a sketch I'll do 'em for ya! :)
