inferno
Can I Relocate My Brake Servo?
inferno
ive just looked at my 406 and realised the brake servo is on the right
now im thinking if i could do something similar on my 309 ill have plenty of room for the turbo pipes! has any1 done anything similar?
DOH... i dont know how to resize pics...
yorkdave
i saw a 205 today at the french car show with a 206 gti180 engine in it and he had put the brake servo on the passenger side, i think he had used the linkage and servo off a 106 or other larger modern pug. I can't be sure what parts he had used but I know he was from somewhere near derby, as he lives near Shenpar who had done him a bike carb conversion kit.
inferno
off to strip a 106 i think then!
inferno
muhahahaha! im going to do away with the brake servo altogether!who needs it?!
TEKNOPUG
Bad idea - both moving the brake servo to the other side and doing away with it altogther.
Just buy a proper manifold for FFS!
Edited by TEKNOPUG
inferno
stop following me unless a tt manifold and t28 is going on yr credit card and being delivered to me!
why is doing away with the servo a bad idea? i think its an ace idea... look at all the extra space ill have! and no more pug fading braking!
Rippthrough
Moving it will give a lot of nasty flex in the pedal.
If you're going to remove it you need a hi spec brake setup with as little flex in the entire system as possible, so you can run a small M/C
inferno
what ... something as high tec as a xantia? or bx16v? well im thinking along those lines... powered brakes as apposed to air assisted... just an idea... i have a choice of abt 15 cars for parts :P
wld a 205 desel M/c be adequate?
Edited by inferno
205turbo
the 180 engined 205 use a mondeo brake master cylinder with a shortained bar,
cost him £20 if he told me correctly
Edited by 205turbo
205turbo
here are the pics of keiths 205 180
TEKNOPUG
Why do you need a T28???? :P A T25 will work just fine. As a previously said, the Xu10 was never designed for a 309, hence your problem.
That 180 still has a servo so I can't really see how that solves your problem. Having a servo on the opposite side to the pedal can't be a good a idea. I think that you're just ending up bodging around the fundamental problem which is the exhaust manifold.
tom_m
the linkage takes up space that the turbo is going to need!
inferno
my t25 has that s*ite flange, so would be rendered useless on a TT manifold.
also, as those link bars to relocat the brake servo r in several modern cars, surely they cant flex much at all?? and the link bar will not interfere with the turbo as itll be too close to the bulkhead to hit it.im a welder fabricator by trade, and work as a citroen specialist, so whatever i do i assure u it wont be bodged just because i dont use a tt manifold!"!!
d-9
dont the standard XU10 manifolds flow really badly?
inferno
i think my turbos too big... thats the problem!
as for the manifolds flowing badly, who cares, my zx was a 139 bhp RGY that was eating mi16 205s and vr6 golfs amongst other moters (on its good days), so im not that fussed as the 309 is lighter and handles better.
Edited by inferno
d-9
lol you should get a 106 engine mate, 140bhp and eats everythign ive bothered to race, and it does 40mpg and fits :P
Edited by d-9
inferno
lol you should get a 106 engine mate, 140bhp and eats everythign ive bothered to race, and it does 40mpg and fits :rolleyes:
would this engine be in the...
309 "GR" 1.9 16v - In the bin :lol:
that got replaced with...
309 GTI auto - Mi16 fitted...will finish one day
which didnt work, or is it in...
106 XSI - So how do i map this thing then....
thats really only 10bhp because you forgot to plug the ecu in first?!
sort it out :)
wasn't eating ANY of the Mi16 205s I've taken you out in lol
cant believe how many times I've had to point out to you that zxs weigh 1200kg or so, more than a bx ffs.
