boeseturbo
Dyno Day For 300 Hp Turbo
boeseturbo
Hey friends of the night :(
My car is nearly finished (will got TÜV (yes I´m a German) next month)... for 3 weeks we do the dyno-trimming of motronic (with upgraded MAP-Sensor up to 250 kpa)...
- 2L Turbo engine from Citroen XM
- Custom Made Exhaust manifold
- Custom Made Inlet manifold with 80mm tb
- machined head
- GT2860R turbo (this one)
- 3" V4A downpipe
- 2,5" exhaust from 200cell metall-cat with 2 absorber mufflers (selfmade)
- watercooled PWR-Chargecooler with second water-cycle and own radiator (no place for air/air ic)
- water-injection (230ccm)
- Ford Injectors 440ccm
- Sachs clutch (organic racing pads) with OMP pressureplate
- squential blow-off (make sounds like whippings :))))
- Brembo 4 pot with 283x26 discs
- OZ Racing Supertourismo 7x16, with 195/40R16 Toyos
- thread-suspension
- and much more :)
We´ve got 200 KW at 5100 RPM and then wheel-spins without ending :)... I think it will make about ~ 220 KW at 1,5 bar... More we can´t measure... have to try it with slicks :D...
Alexander who makes the engine-management-software has exudation in the face while testdriving :))), and I was smiling all the time :D
view pics for you (yes I know, car is very under construction, will do rest of work in the next weeks)...
Edited by boeseturbo
hexhamstu
looks like high attention to detail on this engine! looks like its gonna be a good un.
TEKNOPUG
Turbocharged Sorrento's - gotta love 'em! :(
Look forward to finding out what results you get after it's been mapped properly.
Anymore details on the sequential dump-valve?
tom_m
i'm looking forward to the reults too... i've got that turbo too! ok mine is sat in the garage right now but hey!
thats one short inlet tract!
any more pics?
boeseturbo
Hi mates,
here are some more pics...
Regards
Jan
sonofsam
Looking forward to the results of this one Jan,can see myself doing something like this,maybe in a few years time anyway.
Great stuff,keep us posted
Sam.
rich_w
Good work! going to be interesting to see the results, but wouldn't a 2.5" inch exhuast be a little restrcive for your spec?
Jakob
Great project!
Edited by Jakob
jochem
That's looking very nice indeed!
What water inj. system are you using?
Ruud_Steeghs
Hey,
that sure looks like a DP-engineering setup those parts you are using (intake and exhaust header!!) that charge cooler looks fairly small to me... sure woud like to see a dyno printout off your run cause then i know where i am at with my setup
Regards Ruud
Jakob
I think the short PWR IC is rated to 250-280 hp as far as I remember.
Mine is a bit longer and is rated for 300hp
Mandic
nice setup...
Ziga
Jakob
@ Jan -> What size water pump are you using for the PWR intercooler ?? and which cooling radiator are you using??
My water pump is rated to 26L/minute at Ø20mm, but having the T16 cooling radiator (very high resistance and narrow flow) I am a littel concerned that it might not cycle the water fast enough.
Jakob
Mandic
Forgot to ask You before, which BOV is that? Turbosmart? Looks quite good.
Ziga
Jakob
It is a Sweedish product from JB Raceparts
Edited by Jakob
Mandic
This will sound a bit boyracer-ish, but does it sound good? :blush:
Good site btw,
Ziga
adrian_gti
stunning engine bay. not a drop of oil in sight!
Jakob
This will sound a bit boyracer-ish, but does it sound good? :D
Good site btw,
Ziga
Yes, it sounds good - and LOUT :D
Yes, everything has been removed, cleaned, replaced, testfitted, removed again hahaha etc.
There are 6 pages about the conversion HERE, but it is in danish :wacko: However lots of pics...
Jakob
Edited by Jakob
Dandu
@Jan: It seems to be a pretty good setup. Congratulation! I hope you can trust your luck, while trying to get your MOT approval. Your passion for the 205 seems to be unlimited ... that is, what we've got in common. And what makes me appreciate your work. Good luck!
Bye Dandu
Guest andy309goodwood
wow awsum set up very similar to what i am planing
do you think a single large throttle body like yours or throttle bodys would give better results and do you have any details about the sequensial bov
cheers and awsum build
Jakob
For any setup over 250hp I would change the throttle. It is very small standard. I have used the 58mm (inner diameter) from the 2.0 XS N/A engine.
tom_m
does this bolt straight to the standard xu10j2t inlet manifold?
Jakob
Yes, but you will have to machine the inner diameter of the manifold to have it fit 58mm. However again I would newer use the standard 10j2t above 250hp. THe two runners are way to narrow.
would you be able to tell me what the dia of the in and out let of the pwr cooler is im planning on running the 4x8 one but i could do with knowing what dia the pipe work will need to be cheers
andy
