AndyR 0 Posted May 8, 2006 Hi all Im helping a local 205 owner install my Mi16 engine I sold him, the wiring loom in his car is a little different to my own car. Im installing the loom from the 405 Mi16 Motronic, thats all in. My difficulty is finding the switched +ve wire inside the 205 to bring into the engine bay to connect to the end of the mi16 loom. Same goes for the main earth wire for the loom. Just cant find it, the rest are taken care of. Any idea where these wires go in the car and best place to look. Share this post Link to post Share on other sites
inferno 1 Posted May 8, 2006 stick a multimeter under the bonnet or a test lamp and probe until u find a live thats switched:P or do a search... thats how i found my first wiring diagrams and pin numbers for my very first conversion Share this post Link to post Share on other sites
M@tt 77 Posted May 8, 2006 you could use wire 32 which comes out of pin 8 on connector K of the fuse board this is the main switched feed to the instrument guages and goes through fuse 2, this comes live on the accessories key turn or you could use wire 32a which comes live on the M key setting this was used for the tachemetric relay which you no longer need if you've got the mi and this comes out of pin2 on connector E HTH Matt (now the king of wiring diagrams ) Share this post Link to post Share on other sites
