mbayley77
Xu 10 Engine Sensors
mbayley77
Ok, I am just about to start my wiring for the MI to gti-6 engine transplant. Want to know what sensors are what on the xu10j4rs engine.
If anyone can post a pic or a sketch then that would be useful.
also, seems like the sensors on the Mi are single point spade connectors and the ones on the gti-6 engine are double spade connectors. Is one side of the connector just an earth?
DrSeuss
yes, the sensors on the xu9's earth to the block, later sensors earth directly to the gearbox instead.
mbayley77
thought this might help
I believe the top one to be the knock sensor!
But what are the other two? And also there is a hole where I am guessing there should also be a sensor, what is the missing one?
Also are all three sensors in the water housing the same? If not what one do i link up to the 205 loom?
Thanks for any helps. Just these loose ends to be thinking about now.
mbayley77
Thanks.
Have just been to peugeot and the guy on the counter didnt know what sensor it was missing, and even the mechanic he asked didnt have a bloody clue. ahhh main dealers. if they dont have a part no then they may as well be baboons serving you.
GoodwoodNSM
Post the pic on the 306gti-6 forum some one will know :)
mbayley77
anyone?
sonofsam
Assuming this is the same block as a 2.0lturbo ?
far left being oil pressure,wich i have t-pieced to utilise 205 sender
far(tapped hole) right on mine is were the oil return feed from turbo i think
