allanallen
Will It Fit?
allanallen
405 MI16 rear beam on turbo diesel?
is it an easy conversion to disc
handbrake cable?
is master cylinder up to the job
my t d has abs will it be ok
its a phase 1 mi16 and phase 2 stdt
HELP!!!!
The basic beam is the same, You'll need handbrake cables and the ABS sensors at the rear may not match up to the ABS ECU is the only problem I could see
allanallen
could i get rid of the abs on the back? ie not plug them in??
